Newb from Michigan!
Discussion in 'Member Introductions' started by BlackHawk99, Apr 27, 2009.
  1. BlackHawk99
    BlackHawk99 Member
    Hello from Michigan!
    My wife and I are buying a 1997 Tahoe which we test drove last night. We needed an inexpensive family vehicle and came across this Tahoe. We test drove it and it seemed to drive fine, considering the mileage. It has 212,000 miles, but it drove well. It needs some that's why I'm here!
    -- The air conditioning needs to be charged (my brother is in that line of big deal)
    -- The driver's rear door will not open. It seems to be stuck in the locked position.
    -- There's a small coolant leak coming from the tee at the heater core hoses.
    -- Needs a GOOD cleaning. It's pretty filthy now.
    -- There's an alarm system that acts goofy. I'm going to have it uninstalled from the local aftermarket shop.
    But for having 212,000 miles it ran great. The push button 4x4 worked well. All the power windows worked. Cruise, CD player, mirrors, etc. all worked. Transmission shifted well. The 350 still was maintaining 50 lbs. of oil pressure even at a hot idle. The owner bought the truck with 120,000 in 2003 and drove it all around northern MI and only ever had to replace the fuel pump, a/c condensor, a/c evaperator, and a/c compressor.
    I'm getting it for $1,475. Good deal?
    Getting that door open is my main concern for the time being...
    1 person likes this.
  2. 1st Synthetics
    Welcome to the Site! That does sound like a pretty good deal. What part of Michigan are you from? I am in South Lyon, MI.
  3. BlackHawk99
    BlackHawk99 Member
    I'm from Grand Blanc. Grand Blanc is about 12 miles southeast of Flint, or 50 miles northwest of Detroit.
    I get to South Lyon every now and then. A friend of the family owns a plumbing company and is based in South Lyon!
  4. bry2500
    welcome to the site!!!
  5. BlackHawk99
    BlackHawk99 Member
    Thanks! I've been doing some searches for the issues with the 97...
  6. retired2001
    Welcome to the site! For the price, it sounds like a good deal. The 350's in those years had problems with leaking intake manifold gasket. My '96 leaked at the back, then shortly after that the water pump failed. The mechanic told me that was common at the time. Good luck with the door, maybe someone on the site can help with the door.
  7. BlackHawk99
    BlackHawk99 Member
    I'm assuming the intake gasket has been replaced at some point. 212,000 on the original intake seems unheard of. The intakes on the 3800, 3400 and 3100s all leaked badly too. You were lucky to see 80,000 miles out of those intake gaskets.
    I was able to get the door open last night. The lock was stuck shut. I got the door panel off and worked the rod back and forth. Good as new now!
  8. ct9a
  9. dwill3015
    Welcome to the site and that sounds like a pretty good deal (esp. since the previous owner paid for those expensive repairs).
  10. Scooter
    Scooter Rockstar 100 Posts
    Welcome to the site.
