Newbie here. Hi everyone. 1991 5.7 4x4 1500
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by jbopeep, Jan 27, 2014.
  1. jbopeep
    jbopeep New Member
    What a great forum. Been reading for a while now.I have a quick question. My truck
    idles a little rough. Smooths out as soon as I start accelerating. Runs great then.
    Someone mentioned the EGR valve. Haven't had time yet to check it out. It's been
    really cold the last couple days. Any ideas would be appreciated. Thanks a bunch.
  2. BurbanMan
    Have you done a basic tune up? I.e. Plugs wires cap rotor and fuel filter? This info would help us a lot to narrow down possible suspects. You can take the egr valve off and clean it good. You can also clean the o2 sensors with acetone and a clean red shop rag
  3. jbopeep
    jbopeep New Member
    I'm sorry. I'm new at this. Plugs, cap and rotor and fuel filter have been replaced.
    I'll check the EGR and 02 sensor as you suggest. Thanks a lot.
  4. BurbanMan
    changing the wires would probably help too
  5. jbopeep
    jbopeep New Member
    The wires are only about a year old. But I'll check
    them anyway.
    If a wire is bad, wouldn't it miss while ccelerating also?
  6. DrumBound
    DrumBound Member
    Welcome to the forum...Sometimes. But with increase in rpms you would not notice it. Not to mention sometimes wires fail because your not getting enough power put throigh them, and with that every second or third fire could 'jump' the short and fire at that time. Does it idle rough even on choke starts (first cold start before it warms up)? I have an 88 and after changing the O2 sensor it ran fine, still pops a code every now and again though, probably because my cat, egr, and air pump delete. Not a hard code though, so can't read it after I shut the truck off.
  7. jbopeep
    jbopeep New Member
    Yes it does. It idles rough when It first starts but just idles faster. Where is the 02 sensor located and how difficult is it to change? Thank you for taking the
    time to help me out.
  8. DrumBound
    DrumBound Member
    It is on the drivers side exhaust manifold. Not difficult to change. But having an O2 socket helps alot. Not alot of room in there for a wrench. Maybe get a 1/6 of a turn at a time. Get the Bosch sensor and just splice in the wire to the old connector, cheaper than paying an extra $20 for the connector already on it. Let me know if it fixes the problem.
  9. jbopeep
    jbopeep New Member
    Thanks. I will let you know.
