NO AC! Can't Hold Charge
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by spirittoo, May 28, 2012.
  1. spirittoo
    spirittoo Rockstar
    Hi everybody ... My 96 S 10 will not keep the air cool ... after spending $500 getting it repaired it still won't stay cold! I had the condenser, compressor, and the drier replaced ... what else could it be?:grrrrrr:
    Anyone have any idea what needs to be done ... I pretty much need a AC expert, because my mechanic hasn't been able to figure it out so far ... :no:
    :gasp:
  2. kw70chevy
    kw70chevy Member
    did you replace the orfice tube if it is pluged it will not cool
  3. spirittoo
    spirittoo Rockstar
    Worked for a short while
    Hi there ... well sir ... the AC worked for a few rides ... don't drive it everyday. Do you think the line could have gotten plugged after the fact? My mechanic is checking it out tomorrow ... I will post the results ... Thanks for posting.
  4. kw70chevy
    kw70chevy Member
    yes if you did not flush the system it will plug up the orfice tube.
  5. spirittoo
    spirittoo Rockstar
    Problem Solved :)
    Well sir ... my mechanic check it out and it turn out the seal on the compressor tore ... once it was replaced the air works again. :great:
  6. Coach24
    Thanks for the update. Sometimes new hoses are appropriate when doing the whole system.
    Did you flush the lines while at it?
  7. spirittoo
    spirittoo Rockstar
    I don't know if they did that or not ... he didn't say.
  8. moogvo
    The biggest problem people have with AC is leaky lines. Of the last several vehicles I have brought back from Crusherville, the only AC problem I ever came across was leaks. My '95 had several. I have fixed them as located and re-charged. each time, it works a bit longer than the previous time before the compressor begins cycling.
  9. spirittoo
    spirittoo Rockstar
    Thanks ... I will have to keep that in mind. :great:
