No dash lights
Discussion in 'Audio, Video & Gadget Tech' started by Alleycat, Aug 22, 2009.
  1. Alleycat
    Alleycat New Member
    I own a 2004 Chevy. Sileraldo 2500HD, when I set the parking brake I lost my dash lights. Checked fuses no help, installed a new headlight switch, no help, and swapped some relays ( headlamp rt to lt) no help. I do have power to the switch but no solid ground.What wire color is direct to ground and/or is there no ground?
    Any ideas or solutions would be appreaciated.
  2. 2ToNe04
    ever think the bulbs in the cluster burned out?
  3. bill190
    bill190 Rockstar 100 Posts
    Usually there are a bunch of wires in that area. Maybe one came loose?
    If you don't see anything obvious, then you will probably need the factory wiring diagrams which would be in a GM Factory Service Manual set (order from or a GM dealer).
