    Join Today ~ It's Free
No Heat front or rear
Discussion in 'General Chevy & GM Tech Questions' started by djssub, Jan 5, 2011.
  1. djssub
    djssub New Member
    99 sub 5.7 no heat front or rear already replace t stat both heater cores , coolant refilled system still no heat i somtimes get heat out of the front then it goes away any ideas thanks
  2. KidHauler
    KidHauler New Member
    Did you flush the system before the refill? And did you replace the other stuff because of no heat? It sounds like the radiator may be clogged.
    If it were me, I probably put the t-stat in backwards, but I'm learning to double check these things...
    Good luck,
  3. stephan
    stephan New Member 1000 Posts
    If you've already replaced the T stat, & both heater cores then you're not getting any coolant flow. You aren't getting enough coolant flow to, or through your cores. Check both inlet & outlet hoses.
  4. djssub
    djssub New Member
    it has a new engine all fittings and hoses are new line were cleanes out i flushed everything enginewas replaced due to brother severly overheating it rad was cloggged but cant get heat with every thing new ????
  5. stephan
    I still think this is a coolant flow problem. The hoses may be hooked in the wrong places out front since this was an engine replacement. Can you shoot us a couple pics so we can see where they go? Start at the firewall where the hoses come out & take pics all the way to where they go. I've seen mechs, & first timers just hook hoses where ever there is a bung even though it is not the correct place. If they have hooked your heater hoses to stagnent water sources this will not allow any flow & the only heat you would get to your heater cores, would be by capillary action, which would take forever to heat it up.
  6. djssub
    djssub New Member
    well i finally had time to play with my sub and it turns out the moran who did the engine for me put the hoses off the water pump in the wrong spots i guess thats what happens when you have someone else do work for me i was just to busy at work and home to get to it thanks for the help
  7. KidHauler
    Good to hear you got it figured out.
  8. stephan
    Well that certainly will do it. Switching the heater hoses on the engine is the same as switching them at the heater core, & there's a deflector plate inside the core that if the hoses are hooked backwards will almost stop the flow. Glad you got it sorted out.
  9. djssub
    djssub New Member
    it was dumber then that on the vortecs for the water pump has 2 outlets ont tyo the intake one for the heater the guy hooked it up pump to pump no wonder why i had no heat it also fxed the other problem i was having i should of cought that right away but thats what happens when a master tech has a coworker do it for him lol thanks for the input
