No Heat
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dano8928, Aug 27, 2009.
  1. dano8928
    dano8928 Member
    When i turn the heater on all im gettin is cold air. where should i start lookin for the problem????
  2. ejohnson03
    ejohnson03 Epic Member 5+ Years 1000 Posts
    If the blower is not working on all speeds, you could look at replacing the Blower Motor Resister.
    If the blower works on all speeds (including MAX), then it is most likely the Heater Core.
    Is there any evidence of fluid or moisture on the passanger side under the glove box, dash, or on the carpet up on the firewall?
  3. dano8928
    dano8928 Member
    Nope. no moisture at all. Ive also heard that the lines going through the fire wall could be air locked or even possibly the coolant is low. have you heard of that? i personally figured it would be the heater core too. but i thought id ask about any other ideas. maybe even the thermostat is shot?
  4. zubbiez
    zubbiez Epic Member 5+ Years 500 Posts
    how does your anti freeze look? I once bought a truck that un be know to me had some really dirty looking anti freeze, turned out to be a radiator stop leak some sneeky bastard had put in the truck. long story short that crap had pluged the heater core, I took the heater lines off and blew air threw them until they got unplugged. worked fine after that. oh and if the anti freeze is really dirty Id recommend flushing out the system wheen you blow out the heater core.
  5. Z71_guy
    i would try back flushing the heater core,
    take the heater hoses off at the firewall
    spray compressed air through not to much pressure tho you car rupture the heater core
    take the garden hose with a spray nozzle and fill her back up
