No power at the fuse panel
Discussion in 'Chevy C/K Truck Forum' started by windhunter38, Nov 23, 2013.
  1. windhunter38
    windhunter38 New Member
    The battery is charged and there is power at the starter but when I turn on the ignition key the dash does not light up. I have checked all the fuses at the fuse panel and they are good but there is no 12 VDC at any fuse. My guess is the an inline fuse to the B+ distribution block is blown. I don't have a wiring diagram and don't know where to find such a thing. Any ideas.
  2. tbplus10
    Could be a relay that allows power to the panel, or a bad connection between the panel and battery, possibly a corroded connector.
    What year truck is this?
  3. RayVoy
    You haven't provided any vehicle info, so we need to guess.
    Some (most) GM trucks have a fuse panel under the hood and a second fuse panel inside the cabin.
    The inside panel is fused from the exterior panel, but it uses a larger fuse called a megi-fuse. It will be 75, maybe 100, maybe 125 amps to provide power to the inside fuse panel.
  4. windhunter38
    Truck Type
    My truck is a 1994 34 ft C30. The body is a RV. I have the RV wiring diagrams but the truck wiring is not included. I have found diagrams for the starter, neutral switch and neutral switch relay. This diagram does not show the ignition switch circuit but refers to a B+ distribution block. There is a fuse panel under the hood. No power there.
  5. RayVoy
    Ok, I thought you were talking about a secondary fuse panel not having power. Your saying the main fuse panel under the hood has no power.
    To the best of my knowledge, there is no inline fuse for that panel. There should be one wire providing full time battery power and a number of wires providing other types of power ie: switched battery.
    Pick a circuit that should work when the ignition key is off, ie: the parking lights. Find the fuse and trace the wiring back to the battery. You may have a faulty fuse panel (now, I said maybe, don't start changing it without proper testing).
  6. edsmagichands
    edsmagichands Member 2 Years 100 Posts
    Most Gm trucks have a cable from the battery to the starter and a cable from the battery to the underhood fuse box, some with a mega fuse in this cable.
