NO POWER!! Bogs down!
Discussion in 'Performance & Fuel' started by Avatar, Jan 8, 2010.
  1. Avatar
    Avatar New Member
    Good morning! I have a 1992 1500, 4x4 with the 5.0 in it. It has TBI and the problem I have with it is that when I try to accelerate quickly it just bogs down, no power. I can get up to hwy speeds as long as I massage the gas pedal. Any help? Thanks!!
  2. bigburb
    bigburb Rockstar ROTM Winner 100 Posts
    How long has it been since you changed your fuel filter? Have you ever done a tune-up? Your fule filter could be clogged, or your plugs could be gettin' old. There's a lot of other things that could be wrong, these are just the first two things that come to mind.
  3. 95Chevyk1500
    95Chevyk1500 Rockstar 100 Posts
    mine did that and i changed the coolant temp sensor. it was running really rich. black smoke when i started it up, just really crappy. replaced that sensor, problem solved!
  4. Avatar
    Avatar New Member
    Got it!
    Thanks bigburb! Changed out the fuel filter and now have full power back! Nice, easy, cheap fix!
  5. lmin2
    lmin2 New Member
    Hey suburban owners. I love this site. I have made a lot of fix's and upgrades with your help but I have one issue that I cannot put my finger on. My 2000 suburban hesitates and shifts into overdrive when going uphill and on normal grade takes a while get get up speed even when I press the pedal to the floor..I have checked fuel pressure-ok,changed fuel filter, cleaned throttle body, cleaned maf, cleaned tps(throttle possition sensor) added a cai,changed spark plugs and wires and changes transmission fluid...any other!!!!!!! Thanks.
  6. Stealth
    Does this happen in tow/haul mode too, or just in normal, unloaded driving?
