no power to fuel pump 89 1500 4x4
Discussion in 'Chevy C/K Truck Forum' started by eldoark, Jan 22, 2011.
  1. eldoark
    eldoark New Member
    ok this is the problem...89 1500 4x4 no power to fuel pump. Checked all fuses under dash and also check the fuel pump fuse on the fire wall. I replaced the fuel pump and the fuel pump relay still no pwer at pump and no power at fuel pump fuse. If i run 12 volts to fuel pump fuse i can hear the fuel pump running. any ideas as to what can be wrong or what else i can check or do?
  2. Taddpole
    Taddpole Member
    My 1990 C2500 had a fuel pump module located under the dash near the ECU. I had to pull the glove box liner to get to it. It's attached to to the ECU to the right of the glove box. I think it's what turns the F/P on before the F/P relay pulls in. I don't know if your truck is the same, but you might take a look. The part # is stamped on the module and it used to be available. I guess you could check local junkyards also. It's about 3in long, 2in wide and 3/4 in thick.
    Hope this helps.
  3. eldoark
    eldoark New Member
    thanks ill give it a look and see if i have one of them
