1. PolishSilverado
    PolishSilverado New Member
    Every time i take a left turn there is a horrible squeal/grinding noise I'm guessing its the wheel hub and bearing plus the abs light randomly turns on
  2. j cat
    what vehicle year / 2wd 4wd etc..
    jack up front end and check the front hubs for wobble. check brakes/front suspension/steering etc..
    with the ABS coming on at times this would indicate in most all cases the hubs bearing seals rusted out and the sensor is coveredin rusted grease. remove the speed sensor the grease should be blue if it is rust coloered the hub needs replacing.
  3. PolishSilverado
    Its a 2000 silverado and yes it has wobble
  4. a.graham52
    a.graham52 Rockstar 100 Posts
    needs a hub.
