Nooooo, my streak is over!!! (CEL)
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by McClintoc, Dec 10, 2013.
  1. McClintoc
    Original owner, 13 years, 175,000 miles and I have never had my CEL come on...until today. :grrrrrr:
    I didn't feel, see, hear or smell anything odd so I have no idea what it could be.
    Fortunately, my dad has a code reader and I am having dinner with him tomorrow so I'll find out what it is tomorrow night.
  2. RayVoy
    There goes Christmas, haha
  3. 99'HEARTBEAT
    WOW.....That Is Amazing!!!.....it shows that you have taken Excellent Care of your truck...:great:.......regarding the CEL, is it Flashing or On Steady.
  4. j cat
    ya forget Christmas fun now . maybe santa will give you a free fix.
    probably a p0300 false code.
  5. TRPLXL2
    I'm going to go with a p400-p422, emissions based fault
  6. Pikey
    Yea, I am going with a Po4?? hopefully just a gas cap issue.
  7. McClintoc
    I just checked my codes. The light is on steady. I am getting:
    P0171 System too lean (Bank 1)
    P0174 System too lean (Bank 2)
    I believe this is fuel/air mix correct? "Too lean" meaning too much air, not enough fuel for the amount of air coming in, yes/no?
  8. 99'HEARTBEAT
    McClintoc.....correct regarding the Amount of Air "Too Much" the Sensor's provide a reading of the Air:Fuel Ratio leaving the Engine's Cylinders, and the Vehicles Power-Train/Engine Control Module (PCM/ECM) uses that reading and adjusts to keep the Engine Running at that Optimum Ratio of 14.7:1. If something is not right and the PCM cannot maintain that ratio, but rather there is Too Much Air, it Triggers these Codes.
    ***These Codes Basically mean that the Oxygen Sensor on Bank 1 and Oxygen Sensor on Bank 2 has detected a Lean Condition "Too much Oxygen in the Exhaust"....On V-8 Engines, Bank 1 is on the Driver-Side of the Engine that has Cylinder #1 and Bank 2 is on the Passenger-Side of the Engine,
    ***Here are some of the Items to Check,
    Check All Vacuum and PCV Hoses, Replace and/or Repair if needed
    Check for Leak Downstream of the MAF Sensor.
    Clean MAF Sensor
    Check for a Failed or Faulty Oxygen Sensor
  9. McClintoc
    I have never cleaned my MAF sensor and my O2 sensors are originaly. I figure cleaning my MAF and replacing my O2 sensors is a good place to start.
    What the best way to clean a MAF?
    On a side note, I did not clear the CEL but it was off this morning...
  10. 99'HEARTBEAT
    I would start with cleaning the MAF Sensor, and then check for Vacuum Leaks, as doing these 2-items will cost you very little, and may correct the problem, and for cleaning you want to use Only....CRC's MAF Sensor(Pictured below)and the Video shows how to Clean a MAF Sensor....
