OBD fuse
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by 9191gmc, Aug 15, 2009.
  1. 9191gmc
    9191gmc Rockstar 100 Posts
    my obd doesnt seem to work. Anyone know where the fuse is for that particular item,
    A pic would help if you could snap one..
    01 silv 1500 4x4 v6
  2. Jimmiee
    Do you mean the PCM fuse? There are several OBD fuses as each module has it's own fuse. What is your problem a check engine light?
  3. Z71_guy
    If you talking about the OBD2 port not getting power check the Cigarette lighter fuse thats what it draws power off of
  4. 9191gmc
    thats the one..is that fuse labeled ??? is it the big fuse box under the hood or that small one on the side of the console..??
  5. Jimmiee
    The cigar lighter fuse is usually located inside the cab in the fuse panel. It will be labeled Cigar Lighter. Please explain what's happening with yout DLC? Scanner no workie? Lights not flashing? Check Engine Light on? What's up?
  6. 04SilverChevy
    04SilverChevy Rockstar 100 Posts
    I know for my 04 the fuse is under the hood. 15A fuse. Labeled CIG something.
