Odd Cruise Control Problem
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by jel1957, Nov 5, 2011.
  1. jel1957
    jel1957 New Member
    2007 Suburban (1500, 2WD) Driving from Houston to Dallas today, and got on the highway early morning. With the cruise control on, I flashed my high beams and it disengaged the cruise control. Could not re-engage for a period of time (seems to me the sun was now up, and the headlights were off). Returning to Houston in the afternoon - engaged the cruise - hit the window switch - cruise control disengaged. Has anyone experienced anything like this in their vehicle - thanks for the advice in advance.
  2. pmf608
    That sounds like you're having some sort of computer malfunction. Cruise control, windows, and headlights on that generation are all computer controlled. If it were just when you flashed your high beams, I would suggest a wiring short in the steering column. It is still possibly, but less likely if your windows are causing the cruise to disengage. I would suggest taking a look at the wiring in the steering column to make sure everything is good there, and failing that you might end up having to go to a dealer for that type of problem.
  3. Caddiac
    If you could get the wiring diagrams you might be able to find a common denominator but I think pmf608 is on the right track.
  4. truckfan4life
    truckfan4life New Member
    Ever since I got my 1997 suburban k1500 about 1 and a half years ago, the cruise never worked. Then one day out of the blue "poof!!" it started working lol. It's been working for 4 months now and I have no clue why. I do know this model year of vehicle seems to have some issues regarding wires becoming coroaded and causing strange issues Ie: I'm dealing with a fuse issue right now on the rear passenger speakers/power door locks (hmmm what a strange combination to combine for a fuse block..lol) circut. Don't know if any of this is relevant to your issue but just letting you know from my limited observations and research, there is defiantly a trend on several forums regarding the above mentioned circuits...lol
  5. Caddiac
    If we are talking weird behavior in the 97 - 98 I can write a book! The weirdness points to all of the following components: the multifunction switch, the cruise control module and the ECM. I have decided that since it works perfectly at times and not at all at others, it is probably not the multifunction switch. That switch was replaced once in the past for unrelated reasons. Basically what happens is it will not respond to the accelerate function which would indicated the switch were it not for the fact that it will cut off while going down the road. Or it will loose speed as it climbs a hill until it finally cuts off. If you "help it" with your foot, it will return to normal speed on flat ground. The only thing it does consistently is not be consistent.
  6. GBurb
    GBurb New Member
    Cruise Control Rrratic Behavior
    My '96 had problems kincking out when accelerating or would not engauge. Took the control module off the firewall, disassembled and found the nylon gears severely worn. Ordered used one for a '97 off Ebay for about $50 and replaced the gears. No problems since . Tried to find just the gears without success. Easy repair.
    GBurb
  7. Caddiac
    I am going to check that out! Thanks for the tip.
  8. buckmeister2
    buckmeister2 Rockstar 4 Years 100 Posts
    when it loses speed going up a hill then shuts off, that is an automatic default, and is the way it is supposed to function. in some vehicles, after losing a few MPH uphill, the trans will auto downshift, but that is not the way with most of the chevy's. it is supposed to shut off when it cannot sustain a minimum variance in speed.
