Odd issue
Discussion in 'GM Powertrain' started by jyocum39, Aug 12, 2012.
  1. jyocum39
    jyocum39 New Member
    Ok i have a 98 k1500 5.7 vortec. Ok so here is what is going on. I put a new plentum and intake gasket on my truck and now it will not start. The only way i can get it to start is to advance the timing by 1 tooth and unplug the tps. If i advance or retard the timing at all it will not start. I have checked the tps and even replaced it, the old one and new one where both good. I do not know what to do. When the truck is running and you plug in the tps it dies immediately. Any ideas would be great. I need help bad!!!!!!!
  2. RayVoy
    Toss us some more info.
    Why did you change the intake, was it damaged?
    Can you go back to the old intake and see if it runs normally?
  3. jyocum39
    jyocum39 New Member
    I just replaced the upper and lower intake. I just got the truck recently and it has a lot of miles on it. I heard they were prone to failure so i decided to replace them. Right now the scan tool is showing that its running at 20 degrees out.
  4. dpeter
    Does this engine have a distributer and was it neccessary to remove it to replace the gaskets?
  5. jyocum39
    jyocum39 New Member
    Yes it needed to be replaced. It has a distributor but its fuel injected. Any other thoughts or ideas would be great.
  6. RayVoy
    I think where dpeter was going, it is very easy to replace the distributor incorrectly, resulting in the timing being off.
    You may have to re-time the engine.
