OEM Silverado oil drain plugs.
Discussion in 'Chevy Truck Talk & GM News' started by stchman, Oct 21, 2013.
  1. stchman
    Since I change my own oil, I am asking where can one get the OEM drain plugs for the NNBS Silverados (besides the dealer).
    The ones I am talking about have the rubber o-ring built into the drain plug.
    Thanks.
  2. Conlan Rose
    Autozone sells a few different drain plugs. I used one for my truck and it works great! Its just like the one you described with the o-ring built in.
  3. Als09Sierra
    Or you could just buy the o rings separate for a couple bucks. Mine wore out and I just replaced it.
  4. stchman
    So Autozone sells the drain plugs with the o-ring built in just like OEM?
    The OEM drain plug normally lasts for years, I just want 1 or 2 as a backup.
  5. Pikey
    I would try to get the part number from GM and then order them on amazon. Autozone does have drain plugs like you described. But, they did not have one for my 2002 5.3L or my wives 2008 torrent. You have to take yours with you, because they could not look it up for me. They just try to match what you bring in.
  6. Conlan Rose
    Yah They had mine because the 350's almost all had the same drain plug so it was common. For another truck I would double check your thread sizes or bring yours. Likely the 5.3 uses the same plug as the 5.7.
  7. Pikey
    The 1999-2007 5.3L uses a M12-1.75 threaded plug. The 2011 4.8,5.3,6.0, and 6.2L all use a M12-1.75 drain plug also. So, what conlan found will work
  8. Conlan Rose
    The 350 uses the same thread plug here's the one currently on my truck: http://www.autozone.com/autozone/pa...N-j8ln5Z8gd4w?itemIdentifier=257250_339485_0_
    Most GM trucks have metric bolts and threads because the bolts are mainly made in Canada
  9. Pikey
    I stand corrected!
    - - - Updated - - -
    I am having a hard time finding one with a built in gasket like that, that is also magnetic.
  10. Conlan Rose
    Yah mine is not magnetic. But it is 4 bucks!!
