oil - filter& additives preference
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by uk mac, Aug 2, 2009.
  1. uk mac
    uk mac New Member
    hi from england
    just changed oil in my 96 silverado used 10/30 pensoil with fram filter
    does any one have oil /filter preferance and how about oil additives --wynes---- stp ----prolong etc
  2. 99'HEARTBEAT
    I Use Valvoline Maxlife 5-30 Full Synthetic with Either a A/C Delco or Wix Filter.....I Change My Oil Every 4000....and I Don't Use Any Additives.
  3. Jimmiee
    I use Napa Gold made by Wix. Fram also has several grades of filters. The cheap orange ones are for 3000 mile oil changes. If I had to use a Fram, which I have many times in the past, I get the better model Fram. Fram also makes a racing filter which is a high flow filter with a thicker metal can.
    Everyone on this forum <except me>:glasses: uses Seafoam. Since it's magic I'm waiting until my truck turns into a pumpkin at 100K and then I'll add the Seafoam to reset my odometer back to Zero. LMAO
  4. 2COR517
    Stay away from the orange box. Use WIX, or NAPA Gold, which is made by WIX. I use Valvoline MaxLife 10W-30 High Mileage Synthetic Blend. All my vehicles were purchased used with high miles. If I had a new engine, I would probably run Full Synthetic. No additives for me. I'm curious about the SeaFoam in the sump though. I'll have to do some more reading around here.
  5. vms4evr
    vms4evr Rockstar 100 Posts
    Oil additives
    Stay away from oil additives. Even a decent oil does not require additives. If you run a synthetic then definitely don't use any. Stick with a good quality oil and filter. That's it.
    I agree on staying away from the orange filter too. They spend more money on marketing than building a quality part. They have a notorious rap for bad filter assembly and junk parts.
    I've tried the Seafoam through fuel system. Haven't tried it in the oil as a detergent/flush yet. In general Chevy V8's are not noted for getting full of sludge.
  6. uk mac
    uk mac New Member
    ok thanks for input will change filter asap i do havea pro gauge filter is that any better than a fram seems to be same as puralator
    i think it depends on what my supplier has in stock
  7. blakejake
    blakejake New Member
    I'm also using Pennzoil Platinum as my engine oil. I guess it depends on the type of the oil additive formula. I have once used Lucas before but shifted to Everglide as I wanted an oil additive that is based on the moly-graphene technology. I'm pleased with it so far.
  8. RayVoy
    Blake, an old thread, but a good topic for an argument.
    You say your pleased with your choice of additive!!!!!!!!!!
    Please, what has the additive done to make you happy your using it?
    My 2 cents, most additive are snake oil and some may actually combat the factory additives in the oil.
