oil preasure gage drops, then goes back to normal
Discussion in 'Chevy C/K Truck Forum' started by Kdubb2208, Sep 15, 2010.
  1. Kdubb2208
    Kdubb2208 New Member
    hey everyone, i am new to this site.
    my oil Gage drops down to zero, but only for a few seconds and then goes back up to normal, does anyone know why this is going on? thanks alot,
  2. murdog94
    Id change the OIL pressure sending unit on the back of the block. it is a common problem with these trucks.
    However YEAR, MAKE, MODEL, would help to better ID any other potential problems. Also motor size and tranny to.
  3. William Drexler
    William Drexler New Member
    I had this happen on my 94 Ck1500 5.7 350. It would fluctuate alot and I started to hear an engine knock, well i took it to a mechanic and he did an oil change and used lucas oil stablilzer, fixed the oil pressure and engine knock, 3 months later happened again did an oil change and good as new so that could be an option if you have other issues along with the oil pressure going all over the place
  4. wisoutlaw
    wisoutlaw New Member
    I had this happen on my '93 Sierra with the 5.7. It turned out to be the semi-syn oil the dealer was using. It was too slippery for the pump and when you accelerated hard enough the pressure would drop. I switched to conventional oil and the problem went away.
  5. 04RegencyRst
    04RegencyRst New Member
    I have a 04 Chevrolet Silverado RST has a 6.0 engine 26,000 miles and my oil pressure gauge has been dropping and going back to normal the engine sounds normal... Would like to know if you guys may know whats wrong with it
  6. The Heater
    The Heater Rockstar 3 Years 100 Posts
    Gauges in newer vehicles are electronic, not mechanical. A lot of things can make that happen, none of which may be any indication that the oil pressure is actually low. It could be simply a bad ground connection. If the engine were doing something that bad at 26,000 miles, you would hear noise.
  7. Pikey
    How far is it dropping? Could be the stepper motor that moves the gauge.
