Oil pressure gauge
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by taydan47, Nov 19, 2010.
  1. taydan47
    taydan47 New Member
    My 2003 Silverado's oil pressure gauge just started to max out when engine is started. Is it my gauge, or the pressure sending unit giving a false reading?
  2. 99'HEARTBEAT
    It could be the Sending Unit as you have mentioned or it could be the the Stepper Motor.....is going out.
    Edit:.....I should have mentioned...What and Where the Stepper Motor's Go.....Below are some pictures of the Stepper motor's and where they go on the Dash Cluster,
    There is one stepper motor for each Gauge,
    [​IMG]
    [​IMG]
    [​IMG]
  3. mfleetwood
    Welcome to the Club!!!
  4. longrange223
    longrange223 New Member
    what does the stepper motor do?
  5. 2COR517
    Pull the wire off the sender, put the key on. While the key is on, touch the wire to ground. Should read zero when the circuit is open (not touching) and the gauge should peg when you short the wire to ground.
