oil pressure?
Discussion in 'General Chevy & GM Tech Questions' started by 2wheelmudder, May 17, 2010.
  1. 2wheelmudder
    2wheelmudder Rockstar 100 Posts
    so i put a thread earlier about my check gauges light poppin up, noticed as i started to accelerate my pressure would drop from 20 to 0 then back up to bout 50, runs usually around 60, drops down to 40 every once in awhile, and as i slow it will sometime drop to 20, i have to check my oil still anyone have this problem at all?
  2. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    sending unit?? I would go get a mechanical oil pressure gauge and put on it, to be safe. Cost is around 20 bucks, cheaper than a new motor...my .02
  3. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Sounds like a sending unit because an oil pump wouldnt be so consistantly eratic. They ussually produce progressivly lower pressure until they quit all together.
  4. 2wheelmudder
    thanks guys
  5. 2wheelmudder
    so you guys mean an oil pressure sending unit or recommend getting a mechanical oil sensor? where is the unit located
  6. tiresmokindad
    tiresmokindad New Member
    I have the same problem of yours. I think the pressure of your oil met at maximum pressure. But if you chill it out it suddenly drops.
