oil recommendation
Discussion in 'GM Powertrain' started by ccmnova, Sep 7, 2009.
  1. ccmnova
    ccmnova New Member
    New here - 08 Silverado 1500 with the V6. need some recommendations on brand and weight of oil recommended. Is synthetic recommended ? I use synthetic in all my cars. I did a change on the Silverado at 2000 miles with regular Pennsoil 5W-30. I am using Mobil 1 in my cars and thought I should do the same with this truck.
  2. moosetags
    moosetags Rockstar 100 Posts
    Greetings from the Florida Panhandle
    I use synthetic 5W30 in both my Suburbans. I use the Wal-mart Brand.
  3. Poor Man
    Poor Man Member
    I have been using Mobil 1 10w30 in my 99 GMC Savana since purchased at 46k. It now has 169k with no issues. One thing, though...if you have a leaky engine, don't use synthetic oil until you fix the leaks...Synthetic will multiply oil leaks dramatically.
  4. Hoss2500
    Hoss2500 Member
    I just put Pennzoil Platinum Synthetic 5w30 in my 6.0L.
    Last tank I got 1mpg more and engine sure seems to like it. Seems to run smoother....although that may just be me trying to justify the added expense of using synthetic!
    I went with Pennzoil because of the "major label" synthetics, it is the least expensive and is readily available everywhere I shop.
    Online reviews looked good too.
    Hope this helps.
  5. ccmnova
    ccmnova New Member
    Thanks for the input. I think I'll try the synthetic oil which better handles the heat (and cold).
