Old New Couple to Alaska
Discussion in 'Member Introductions' started by jakethomp, Mar 3, 2009.
  1. jakethomp
    jakethomp New Member
    Hello,
    We're a couple 83 years old with a yen to drive the Alaska Highway again after first doing so in 1955. This time we'd use the Cassiar Highway as part of the trip. Has anyone done this or anything similar? We have a 1999 Chev Suburban K1500, 5.7 engine, with 160,000 mostly commuter/highway miles by the first owner. We have proper equalizer hitch and sway bar and would pull a Holiday Aluma Lite trailer, 23 feet long, weight about 4,500 pounds loaded.
    Where do I find my rear gear ratio?
    Thanks much.
    Jesse Thompson
  2. dwill3015
    Welcome to the site Jesse! Ususally you can determine your ratio by using the "RPO" codes listed on the white sticker inside your glovebox. Mine lists the code "GT4" which is the code for 3.73 rear axle ratio. Here is a list of all the "G" RPO codes that might help you.
    G44 : AXLE REAR 3.07 RATIO
    G51 : SPRING REAR, HEAVY DUTY, VAR 2
    G52 : SPRING, RR, 15000 LBS
    G5O : SPRING REAR, HEAVY DUTY, VAR 1
    G60 : SPRING REAR, AUXILIARY
    G66 : LEVEL CONTROL, MAN, AIR
    G67 : LEVEL CONTROL, AUTO, AIR
    G69 : LEVEL CONTROL, AUTO, AIR, HD
    G72 : AXLE REAR, 2.14 RATIO
    G75 : AXLE REAR, 3.62 RATIO
    G80 : AXLE POSITRACTION, LIMITED SLIP
    G87 : RING GEAR, 8.50 INCH
    G89 : RING GEAR, 7.50 INCH
    G92 : AXLE REAR RATIO, PERFORMANCE
    G9S : AXLE REAR RATIO, ECONOMY
    GH0 : AXLE REAR, 3.54 RATIO
    GH2 : AXLE REAR, 2.29 RATIO
    GH3 : AXLE REAR, 2.77 RATIO
    GH4 : AXLE REAR, 2.92 RATIO
    GK9 : AXLE REAR, 4.63 RATIO
    GL3 : AXLE REAR, 6.17 RATIO
    GM1 : AXLE REAR, 2.59 RATIO
    GM3 : AXLE REAR, 3.45 RATIO
    GM8 : AXLE REAR, 2.56 RATIO
    GQ1 : AXLE, STD RATIO
    GS4 : AXLE REAR, 3.70 RATIO
    GT4 : AXLE REAR, 3.73 RATIO
    GT5 : AXLE REAR, 4.10 RATIO
    GT7 : AXLE REAR, 3.33 RATIO
    GT8 : AXLE REAR, 4.10 RATIO
    GTY : AXLE, WIDE TRACK
    GU1 : AXLE REAR, 2.41 RATIO
    GU2 : AXLE REAR, 2.73 RATIO
    GU4 : AXLE REAR, 3.08 RATIO
    GU5 : AXLE REAR, 3.23 RATIO
    GU6 : AXLE REAR, 3.42 RATIO
    GV2 : AXLE REAR, 5.83 RATIO
    GV4 : AXLE REAR, 3.36 RATIO
    GV8 : AXLE REAR, 2.72 RATIO
    GW4 : AXLE REAR, 3.31 RATIO
    GW6 : AXLE REAR, 3.27 RATIO
    GW9 : AXLE REAR, 2.93 RATIO
    GX3 : RATIO,TRANSAXLE FINAL DRIVE 3.33
    GYS : RATIO TRANSAXLE FINAL DRIVE 3.65
  3. Z71_guy
    welcome to the site
  4. MOJ06
    MOJ06 Rockstar
    welcome to GMTC.. Great info dwill!!!
  5. ChevyFan
    WOW! Welcome to the site! I would love to get more information on this and see if you can take some photos of your adverture and share as much as your comfortable with. What'a great trip idea!!
  6. adampaul1964
    That's awesome! have a safe trip and keep us posted. :glasses:
  7. MWright936
    Welcome to the site! Sounds like an incredible trip! Have fun!!
  8. retired2001
    Welcome to the site! I'd like to take that trip in my Winny one of these days, but I want to get the "new" off of it first! Have fun!
  9. ct9a
    Welcome to the site! Have a great, safe trip.
  10. bry2500
    Have a safe trip.
