On Board Air (OBA) compressor & tank mounting locations?
Discussion in 'Chevy Truck Accessories' started by SurrealOne, Jun 8, 2012.
  1. ahmitchell1
    I haven't completed my system but I have my tank mounted where my spare tire used to be. It's nice and tucked up. I think my compressor is gunna go in my tool box and have a hose reel inside the box so I can pull it out and then it'll rewind it self back into my box
  2. troutbug
    troutbug Rockstar 100 Posts
    Surreal, what do you plan to use air for mainly, if you don't mind me asking? Engine driven compressors put out a lot of CFM, you may be able to get away with a small tank, or possibly no tank. I have an old York compressor sitting in storage, but it seemed like to much work for what I needed it for, plus I didn't know how much of a strain it would put on my engine. If you decide not to go the EDC route, there are other good 12V compressors....Air Zenith is one that comes to mind. Oasis is another, but you're going to spend a pretty penny for that one.
    ---------- Post added at 11:50 PM ---------- Previous post was at 11:44 PM ----------
    I agree, I don't think the size of the holes required are going to weaken the frame one bit. My two smaller tanks are actually strapped to the frame using really long SS hose clamps, fed through a couple of factory slots in the frame.
  3. SurrealOne
    Air horns, airing tires, and occasional tools use. Tools that might be used require 4-6 CFM @90psi (I checked), so I'd need to use a regulator and probably need a tank, as an EDC will produce the CFM but it'll be at more like 60psi.
    Tool use is my worst case scenario and while it'd be occasional I'm now designing around that so that I have capacity if/when I want it ... rather than installing an electric (sub 2 CFM) unit and then having remorse about it. I'm also learning that a DIY EDC should be a heck of a lot cheaper than any pre-made kit ... which is one more reason it's appealing ... as it provides more ... for less costs less. Also, the kits seem to skimp; I'd prefer to use braided lines, if possible, and I've seen no kit that has them.
    Would you, by chance, be willing to take a photo of this so that I can see how and where you've done it? Re-inventing the wheel seems pointless and if someone's got a solid mounting mechanism and placement for the tank then it would make sense for me to adopt it, myself, to benefit from that experience.
  4. troutbug
    If I get a chance this weekend I'll try to snap a picture or two. I need to get under there anyway and remove the EVAP canister for cleanout or replacement.
    FYI, I used DOT airbrake lines and fittings on my whole system. Haven't had any problems going on 3 1/2 years now.
  5. aloxdaddy99
    Sur I am of the same thought as others in drilling new holes. Shouldn't be an issue for strength. I have seen people use there side steps as tanks. Just close the ends up and tap in a PSV (Pressure Safety Valve). Your issue was with fear of issue's in an accident. There would be a breif rapid release of pressure but it is short lived. As long as the compressor doesn't put out large amounts of air. I have had to make repairs on pressurized lines and just removed a fitting and used a rag folded as a "mit" to catch the fitting after the inital "blast" of air. As far as running pipe I would use both flex and hard pipe. When you get to that stage give me a ring. Or we can go over it later in the month when we get together for an adult beverage.
  6. SurrealOne
    Thanks, Alox. I'm not too keen on use of my step rails in this fashion. I think it's brilliant on paper but I also feel that a lot could go wrong with it. They're lower-slung than I'd like air tanks to be.
  7. DrakeC504
    DrakeC504 New Member
    Do you still have your spare tire? On my friends '05, we took off his spare and made a custom bracket which litterally took no effort in making.
  8. SurrealOne
    My OEM spare is removed. I'm going to attempt to mount a matched full-size spare in its place; we'll see how that goes this weekend. Even if it fails, I -will- find a way to carry a full-size spare in the stock location ... so that location is out for mounting other things.
