? on removing jack container
Discussion in 'General Chevy & GM Tech Questions' started by GaryG, Mar 13, 2010.
  1. GaryG
    GaryG Rockstar 100 Posts
    I have a 98, an my jack is still underneath the bench seat in the back, how do I remove the plastic box? I saw one bolt to remove, but then there is the rod with a nut at the bottom of it, which isnt coming loose. Besides those 2 isn't there anything else that is holding it down?
    Reason I'm asking is because I just got a sub box, 2 subs an a amp for free (I work at a car dealership, an the vehicle it came out of was traded in)
  2. chevorletvol
    chevorletvol New Member
    i have the exact same problem. did you figure it out?
  3. GaryG
    i havent had time to mess with it. 11/32 wrench might work but there isnt much space to get to the nut, that stud is the only thing holding me back right now
  4. 2wheelmudder
    2wheelmudder Rockstar 100 Posts
    i know that stud that holds the lid down can come loose, i have had to tighten it down, the very top of it is actually a hex head bolt as i do remember you have to unscrew at the the top of that rod as i can remember
  5. GaryG
    If its that easy I'm going to slap myself for not looking at the top LOL I would check tonight but I have wheels sitting in the back
  6. GaryG
    Problem! I don't have a hex head on mine. Anything else I can do? If not I'm just going to destroy the box until I get it out of my way. I'm tired of having my subs in sight
  7. kawasaki_kid
    kawasaki_kid Rockstar 100 Posts
    I have a 98 extended cab as well, i removed my jack box to make more room in the cab for among other things, subs as well. what i did was got a good sharp set of vice grips, locked em on as tight as i could, and turned that rod out. it took a couple trys, but once i had a nice flat spot at the top the pliers eventually grabbed good enough.
