One More Rear End Question
Discussion in 'GM Powertrain' started by Tom Evans, Oct 15, 2011.
  1. Tom Evans
    Tom Evans Rockstar 100 Posts
    The shop has started rebuilding my rear end. It's a 2002 1500 Surburban with limited slip differential. They are going to add the GM additive (GM PN 1052358) before I pick up the rear end. Their salesman said that with this additive, I didn't need to use 75W-90 synthetic oil, but could use any name brand 75W-90 oil which complied with GL5 specs.
    GM recommends synthetic oil in the owner's manual, but makes no mention of the additive.
    If I have the additive, do I need to use synthetic gear lube?
    Thanks.
  2. Jimmiee
    If you have the G80 you don't need any additive. The easy way to tell is jack up your rear end with the trans in park.E Brake off. If you can turn one wheel and the other turns backwards you do not need any additive. If you can't turn one wheel or the other in park you need an additive. All rear diffs can use synthetic fluid. It is more expensive and worth the extra cost.
  3. LURCH
    LURCH Rockstar
    X 2 !!!!!!!!
  4. dsfloyd
    What they said
  5. Tom Evans
    Let me put it another way. I think they may have already finished the rear end rebuild. If they have, they have probably squirted the additive in the rear end. The question now is will the additive do any harm with synthetic gear oil?
  6. LURCH
    LURCH Rockstar
    I use it with my Amsoil syn. 75/90.
  7. dsfloyd
    No it wont do any harm
