Optima batteries
Discussion in 'GM Electrical Tech' started by reggiecab2000, Sep 10, 2012.
  1. reggiecab2000
    now made in mexico!?!?!?!?!
    what in the hell???
  2. ChromeSilver02
    ChromeSilver02 Rockstar 4 Years 500 Posts
    Sadly it doesn't really surprise me :no:
  3. sfdefender24
    sfdefender24 Rockstar 4 Years ROTM Winner 100 Posts
    I'm not to shocked by this statement unfortunately. Seems like alot of what use to be made in the USA in now made in Mexico or some other foreign country.
  4. SurrealOne
    This isn't news. Construction of the plant in Mexico commenced in 2000 and Optima batteries have been made in Mexico for the last ten years (or slightly longer). The U.S. plant was closed for good in 2009.
    Prior to going the dual battery route my reserarch showed that reliability supposedly went down when manufacturing transitioned south of the border ... which is why I didn't and won't buy an Optima.
  5. reggiecab2000
    well i just got one the other day and installed it...
    hopefully i will have some good results, i didnt do too too much research because when i researched them about a year ago people were still saying great things about them, so i hope to have luck with this one
  6. SurrealOne
    I wish you luck with it, as well. I went with Die Hard Platinum AGM batteries as my research showed them to be re-branded Odyssey batteries ... with a better warranty than Odyssey batteries tend to have ... for less money than they tend to cost.
  7. zigger215
    Those AGMs are very reliable surreal!
  8. SurrealOne
    I hope so, they are stupidly priced. The nice part is that if one croaks I can just take it to a brick & mortar Sears shop pretty much anywhere and get it replaced.
  9. barefoot greg
    barefoot greg Rockstar 100 Posts
    Looking into these, not sure whether i should get the red top or yellow, i currently have 12" subs, a 1000 watt amp and a 180 watt head unit, the stock battery seems to function fine aslong as i dont leave the stereo playing with out the engine running, if i do then my battery will be flat after only an hour or two, im guessing i should probable get the yellow top since duration is one of my interests but perhaps the red is better than stock already and will suffice. I plan to add a winch, atleast 4 if not 8 lights, a air horn that will require a compressor and a cb so im thinkin i should get the yellow. Any thoughts or suggestions is appreciated
  10. Enkeiavalanche
    Before you waste your money on Optima Batt's Check out Kinetik http://www.kinetikaudio.com/2009/default.asp It's what more pro's are useing.. Odyssey also makes a good one..
    As for what you have now Your radio does not give 180 watts it's about 18-22 X 4 at tops or about 80 watts Total What amp are you running?
