Ordering parts - Cam, CAI, long tubes
Discussion in 'Performance & Fuel' started by 1BadV6, Feb 27, 2014.
  1. 1BadV6
    1BadV6 New Member
    Been debating a cam upgrade and finally decided its time to get it done. Truck just doesn't perform the way I think i should and want a bit more out of it. what I'm working with
    2003 Sierra SLT
    Extended Cab Short Box
    5.3 4L60E
    20" wheels 285/50
    Bone Stock except exhaust, hooker Aero Chamber single in dual 2 1/2 out
    Trans has 4000 miles on fresh rebuild with alto clutches, hardened front drum, updated sprag, extra 3-4 clutches, Sonax performance pack, Sonnax 2nd and 4th gear super hold servos.
    210,000 miles on motor - no issues
    This is my DD and used quit often for towing
    Parts list I've put together...
    Comp Cams XR265HR
    265/271, Lift .522/.529 114LSA
    Comps hardened pushrods #7955-16
    Comp Beehive LS6 valve springs #12499224
    K&N CAI
    And I'm gonna give the E-bay SS longtubes a shot with NO CATS.
    Most likely gonna have the truck dyno tuned locally, if not I'll order a tune from Black bear
    Just curious if anyone sees anything I'm missing or has a different opinion on parts. Just looking to make the truck enjoyable to drive again but retain my towing abilities
  2. 00chevy53
    00chevy53 Rockstar 100 Posts
    check out texas-speed.com look at the packages they put together and compare to what you have. i will say that you should upgrade your oil pump and you need to get new roller rockers for the new cam. some people will say its not needed and would be right but is strongly recommended.
  3. tbplus10
    Are the 20's factory?
    What gear ratio is it running.
    Build all the horsepower you want, if the gearing isnt right itll never perform the way you want it to.
  4. dobey
    Or if the tire diameter is different from factory, the gauges might just read wrong, and make you think it's not performing how it should be.
  5. 1BadV6
    1BadV6 New Member
    3:73
    Not factory, however a 285/50/20 is a 31.2" tall tire compared to the factory 265/75/16 being a 31.6" tire. Speedometer is correct, and performance is the same with 20"s and factory wheel and tires
  6. TRPLXL2
    If you don't want to run roller rockers, at least consider the trunion upgrade for the stock rockers. Everything else looks good, the 3.73 will be a great gear with the setup your looking at.
  7. dobey
    Unless you've changed the system to handle the adjustment, your speedo is reading 1.4% too fast. So if you measure 0-60 time by the speedo, you're actually measuring 0-59 time.
    More importantly, if you don't think it's performing how it should, what you never stated in your original post, is how you think it should be performing, nor how it actually compares to how it is performing now. All those mods are certainly mods, but they may not actually do what you think they'll do, either. Do you know what you want the truck to do in terms of performance exactly?
  8. Darrin88
    Darrin88 New Member
    How big of a lift can you go before you have to replace the stock trunions?
  9. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    I concur! I have recently re-geared to 4:11's and am a happy camper but am considering to go "Long Tube" and a "Mild Cam"! Re-Gear will pro-pell the truck with minimal input with the foot and stay in the gear of the transmission
  10. 00chevy53
    If your going past a mild cam or close to .600 lift I would deffenatly get better than stock rockers..
