Output shaft seal
Discussion in 'GM Powertrain' started by thejms, May 7, 2009.
  1. thejms
    thejms Rockstar
    I have an 02 Sierra 2500HD. Auto trans with the 6.0L. My transfer case started leaking at the output shaft seal. No prob, I thought. I went down to checker autopart and got a new seal. When I went to put it back in the transfer case, the seal is loose, its not sloppy loose, but I can shove it in by hand and I can also spin the seal while seated in the transfer case. I thought maybe they gave me the wrong seal so I took it back and got another. Same outcome with new one. So then I went to Napa, hoping they had something else. Turns out its the same brand, I bought it anyway, just in case. Same outcome. I cleaned the old one up and tried to shove it in by hand and you can tell that it would actually take a hammer to get it in, like its supposed to. Has anyone had this sort of problem?
  2. GaryL
    Sounds like they got a part number wrong, can you take your old one in and have them try to match it up. Maybe select a different truck from 02 to start your search.
  3. blueZ71
    blueZ71 Rockstar 100 Posts
    see if you can buy it off amazon or some other online retailer. i got a fuel pump and sending unit from ac-direct off amazon for 230, acdelco brand and all. 50 cheaper than some lame autozone brand
  4. thejms
    thejms Rockstar
    Well I just went to the stealership and got one, almost 2x the price of the napa ones. Fit like a champ though.
  5. RADO_4U2NV
    RADO_4U2NV New Member
    They were robly giving you the seal for a 4L60E and not the seal for the 4L80E you have. The transfer case is different size between the two.
  6. blueZ71
    Bummer.. well at least you got it fixed
