P1351 check engine code
Discussion in 'General Chevy & GM Tech Questions' started by 2000liftdsuburban, Oct 8, 2009.
  1. my moms 97 tahoe sport has been having a starting issue thats pissin me off.... it's got a good tuneup(plugs.cap.rotor.wires) i changed the coil and the ignition control module as well and still the code stays on there it sounds like it's missing when it does get started however.... anyone have any ideas?
    it's a 350 motor vortec
  2. dsfloyd
  3. that links not working lol...
    yeh i beleive i tried almost everything most common with this issue. i;ll check fuel pressure maybe i;ll be able to figure something out... now if there is no fuel pressure where would i start???
  4. dsfloyd
    it worked just a minute ago but I will try to find it again
  5. dsfloyd
  6. Loggerhead Mike
    the code is for ign coil control circuit high voltage. doesnt neccesarily mean you have high Voltage but its a good possibility you have a short
    you need to focus on possible faulty ground or feed from ign module, poor connections at vcm or a failed vcm
    make sure you dont have any loose connectors
  7. well i have recently searched for the same issues around all seem to be poiintng to fuel issues
    the other day mom drove the truck and it started up fine she drove down the road and it just died, no warnings just shut off...
    i beleive it's fuel related i have to hook up a fuel gauge to it under the hood...
  8. Jimmiee
    Most of the time a P1351 is caused by an ignition switch problem from what I've seen.
  9. thats what my uncle said to me too...
    b.c we changed the coil,igni control module
    so it could possibly be the ignition switch than right
