Painting stock wheels?
Discussion in 'Chevy Truck Accessories' started by zachmilz, Oct 5, 2010.
  1. zachmilz
    zachmilz Rockstar 100 Posts
    I have a 2005 Silverado Crew Cab with the 17" chrome wheels and I really don't like the chrome and I don't have money to buy new rims and tires. What's the best way of going about painting the wheels? Should I just sand them down really good with 600 grit sand paper and put 3 coats of Rust-Oleum black wheel paint?
  2. ajarman
    If you would ever want to go back to your stock finish I would look at Plasti dip. It comes in black, red and white I believe. I am going to do my stock '08 wheels in black in a few weeks. No prep work just tape off and spray. The cans are about $6 each and should take about 5 cans to do all 4 wheels. Check it out!
  3. silveradotrailblazer
    Will the Plasti dip hold up to the heat from the brakes and wheels?
  4. SmokeU
    SmokeU Rockstar 100 Posts
    Interested and looking at doing this as well
    does plasti-dip come in a spray? I also dont think it will hold or look very nice as it would be hard to get an even coat with out it being in spray form
    googled and came up with this that looks preety good http://carbodywork.blogspot.com/2006/11/paint-your-car-rims.html#comments
    in summary
    sand with 300 grit, tape and cover everything you don't want painted (tires, valve stem, ground, etc) paint, dry, clear coat, admire beautiful new rims :)
  5. vms4evr
    vms4evr Rockstar 100 Posts
    I've done GM aluminum wheels with Rustoleum wheel paint. My track wheels, stock Z06 wheels, are painted with the graphite color. This stuff is gritty with metallic bits so not the choice if you want a smooth finish. Black or other non-metallic color would work. Get the clearcoat, wheel paint version, also. Then you can make the shine last better.
    The stuff us heat resistant. My track wheels have race slicks on them sitting over 6-piston race calipers and race pads. Seeing temps in 600-800 degree range on a road course is typical. I've tested with brake paint on the rotors to see how hot they get. The wheel paint has not broken down, chipped, or faded due to the heat. So for a street vehicle it should be no problem.
  6. ajarman
    Yes, it will hold up to heat like a champ. This is really big in the VW forums and they all have had really good luck with this
    It comes in spray can and in a liquid. The spray can would be used for wheel applacations and it does turn out in a pretty even coat. I hang out with V Dubbers sometimes and I have seen a few wheels done in plasti dip and it is hard to tell from powder coated wheels when done right.
  7. RSMark5
    RSMark5 Member
    No do not sand. If you sand the wheels plasti-dip is not reversible. Its very easy to get an even application if you concentrate and have a little experience. It holds up fine to heat. I know multiple people who use plasti-dipped wheels for auto-x.
  8. tbplus10
    I used Plasti-Dip on the inside of the wheels on my wifes HHR about 2 years ago it's held up real well over the last two years, one complaint I do have is it's a little harder to get all the brake dust and road grime off of the plasti-dipped area, thet dont come as clean as before but since I painted them satin black it doesnt show as bad either.
  9. 01BlackBeauty
    01BlackBeauty Member
  10. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    i know i gets pricey but powdercoating is your best bet if you want something that will last, other wise spray bombs are fine but put down a good coat of etch primer
