Park or nuetral?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by RangerJ, Jul 18, 2013.
  1. RangerJ
    RangerJ Rockstar
    1994 Z-71 4x4 auto.What is the best way to check trans fluid Park or neutral? Thanks
  2. RayVoy
    P or N is the same as far as the internals of the tranny are concerned; but for safety, use P, the truck won't roll over the person checking the fluid level.
  3. RangerJ
    RangerJ Rockstar
    Thanks RayVoy.Have a good one.
  4. RayVoy
    Thanks, I was being a little sarcastic, but it was intended to be in good fun.
    While your checking fluids, check the two diffs and the t-case. Probably won't hurt to change the diff and t-case fluids while your at it.
  5. RangerJ
    RangerJ Rockstar
    No offense taken.LOL how do,I check t-case?
  6. RayVoy
    The fluid should be just below the bottom of the full plug hole (level ground)
    [​IMG]
    If you want to change the fluid, try a search where Conlan Rose was asking about fluid types.
    Here is one:
    [​IMG]
    Oh, BTW, be sure you can remove the fill plug before you remove the drain plug.
  7. RangerJ
    RangerJ Rockstar
    Thanks for the info again. :great:
  8. j cat
    the most important step is make sure the fluid is at normal operating temp , having driven it for about a half hour or so of normal driving. then make sure your on level ground. try to park in the same spot to re-check the fluid. next is never over fill or you will create air bubbles and that will cause rapid tranny failure.
    I would use the up dated dexron VI fluid not dexron III.
    if the stick has gray on it drop pan and replace filter/fluid.
  9. RangerJ
    RangerJ Rockstar
    Thanks J cat,
