Parking brake light staying on
Discussion in 'Lifted & Offroad Suspension' started by 95rednc, Aug 23, 2009.
  1. 95rednc
    95rednc New Member
    The red parking brake light on the dash will not go off anymore, any ides on how to fix this.
  2. Z71_guy
    check your brake fluid level first
  3. zubbiez
    zubbiez Epic Member 5+ Years 500 Posts
    Try crawling up under your dash where the brake pedal is at up inside there is a little copper switch that is a ground for the parking lite insure that its not making contact when the brake is disengaged and it should turn off! My truck failed inspection for that reason last year. hope this helps.
  4. 2COR517
    Try using your left foot to pull the pedal up while you pull the release handle. Of course, you could actually have a problem such as a leak.
