Discussion in 'Chevy Truck Accessories' started by Fork, May 13, 2009.
  1. Fork
    Fork New Member
    What is the best way to remove wax from plastic....fenders and bumpers... is there something i can buy to take it off...or rub it off with gas or WD40 anything
  2. raiderman8112
    raiderman8112 Rockstar
    i use simple green and a very stiff toothbrush, it takes it right off
  3. cascott325
    i just rubbed it off after a good rain. keep it wet for a while, then try rubbing it off, maybe try the tooth brush thing
  4. nickgiacalone
    nickgiacalone Rockstar 100 Posts
    that is the same method i use. we had a thread not too long ago about this same issue. if that doesnt work you can try Mother's Back to Black found here
    i have never tried the mother's stuff but some guys on here says it works well
  5. raiderman8112
    ive tried the back to black but it doesnt seem to work well for me at all....
  6. Dr_Zero
    Havent tried on plastic but it used to get in the louvers on the mustang and I would use a Q-tip dipped in rubbing alcohol to get the wax out of the grooves.
  7. Fork
    Fork New Member
    What kind of simple green. i bought some stuff in a squirt bottle i think it was all purpose is that what you used to take off the old wax
  8. nickgiacalone
    Yes, this is what I use I buy it in the gallon jug tho. I use it for anything you can think of around the house. Its great for cleaning carpet and cloth seats as well. Plus, it leaves a great smell!
  9. silveradotrailblazer
    Heres a trick I use before I wax. Apply a good amount of any armor-all type protectant on all the plastic and leave on while you wax your truck. After wax dries wipe off protectant and then remove wax. Any wax that got on plastic will wipe off with the protectant.
  10. 97chevz71
    97chevz71 Rockstar ROTM Winner 100 Posts
    All you need to do is get some kind off all purpose cleaner. If it is good stuff diluted 50/50. spray it on your plastic and scrub it then rinse off. Then put your dressing on your plastic. I use Adams All purpose cleaner and adams Vrt on my truck it is the best by far.
