Please help me!! 1999 sierra, no power
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by KpuntryBoy82, Nov 7, 2013.
  1. Pikey
    The oil light is most likely caused by a bad oil level sensor, they are around $25. That sound on the right side does not sound good. Maybe, @j cat will get a chance to listen to the video and can help out on this one. He is very good with this kind of thing. Just out of curiosity have you checked your fuel pressure? You can borrow a fuel pressure gauge from almost any parts store for free. you might want to check it just to eliminate fuel delivery as an issue. The gauge simply screws onto a port on the driverside fuel rail on top of the motor.
  2. KpuntryBoy82
    KpuntryBoy82 New Member
    Have not checked the fuel pressure but I'll look in to that.
  3. j cat
    I would check compression. also do a coolant pressure check ...head gasket / cracked head etc...my guess.
  4. KpuntryBoy82
    So its not guaranteed that there would be water in the oil or vise-versa with a blown head gasket or cracked head? Bc I am not experiencing either that I can tell. And can I borrow a compression tool from say Advanced Auto?
  5. j cat
    the heads and head gasket is one failure .. the other would be coolant leaking into the intake port.
    call autozone or another store for test tools.. get the coolant pressure tester..
    if you find coolant leak then the compression is good. check spark plugs for coolant..this will show a very clean plug as the water removes all carbon deposits..the plug will be the odd colored one..then this may be the intake gasket but some have had crack in the head with this..
