please help me
Discussion in 'Performance & Fuel' started by heavy chevy, Feb 22, 2009.
  1. heavy chevy
    heavy chevy Epic Member 5+ Years 500 Posts ROTM Winner
    I have a superchips cortex programer. I was wondering if a custom tune would be better than the superchips setting that is in the tuner. Also i would like to get a custom tune done on the truck to get the most power out of it i can. Any suggestions will help.
  2. 95CTburb19
    95CTburb19 Epic Member 5+ Years 1000 Posts
    From what I have seen, custom tunes will generally give you better performance. Provided that the tuner knows what they are doing.
  3. ct9a
    I'm not sure what the extent of the programmer allows for. I do know that if you're not a tuner, or the programmer only uses preset factory tunes, then a custom tune would probably squeeze more gains out of your truck. The down side is that if you do anything to change the way the truck runs, new injectors, exhaust, intake, etc. you will need a new tune. If you live in an area where temperature and humidity changes drastically from season to season (I live in Colorado, so this would apply to me), then you could see problems in the winter if your truck was tuned in the summer, or vice versa.
  4. heavy chevy
    thanks for the help
  5. thatjerk01
    thatjerk01 Rockstar
    another thing with a programmer some inprint numbers into the computer so it can void factory warranty and the computer has adaptive learn so it learns how u drive well the computer can over throw the programmer. learn around it.
