Please someone help asap
Discussion in 'General Chevy & GM Tech Questions' started by lqvision, Oct 15, 2009.
  1. lqvision
    lqvision New Member
    hello im new at this and really need some help.
    i have an 03 silverado. 4.8L v8 2 wd.
    my truck was in park and i heard like a whining coming from behind the cab. then i was driving and the engine was like sputtering, like running out of gas, then on the dash it said "service brake system", then totally shut off and wont start. not even turn over. anyone out there no anything. please help. thank you so much
  2. 99'HEARTBEAT
    You got to help us,so we can help you......What's the of the Year Truck ,2wd or 4wd.??????????
  3. lqvision
    lqvision New Member
    sorry my bad i forgot. its an 03 chevy silverado 1500 ls. 4.8 L V8. 2wd. 83k miles. auto trans.
  4. lqvision
    lqvision New Member
    i went to autozone and got one of those diagnos computer things and it wouldnt communicate with the computer in the truck
  5. 99'HEARTBEAT
    You have mentioned 3 Items......I'm guessing here the whining could be the Transmision??,....Truck Sputtering could be a number of items,Injector's,....Fuel Filter or Fuel pump.and with the Service brake light coming on it could be the brake fluid is low,....your pads need to be Replaced......I was going to mention going Auto Zone, and check what code's are coming up.
  6. lqvision
    lqvision New Member
    what are the chances of all thoses thing at the same time. brake pads are good and so is the fluid. the abs light is on as well. just had the injectors checked their great. you think the whining behind the cab could be the fuel pump? the low fuel light had just come on before all this happened.
    because it wont turn over you think is could be electrical, ECU, fuses, battery, ...
  7. 99'HEARTBEAT
    I thinking that it might be the Electronic Brake and Traction Control Module...I had Whining just like you Mentioned on my truck, and that item is under the Driver Side Door on the inside of the Fame Rail.
  8. lqvision
    lqvision New Member
    would those two thing shut the vehicle off? and your not able to start it again
  9. 99'HEARTBEAT
    If the fuel pump is the Problem Ya......Your truck is not going to Start, I would try to find someone who can pull the codes from your truck....That is really the only way to find out what the problems are.....
  10. lqvision
    lqvision New Member
    ill do that. thanks a lot for your help. you too
