plug and wire suggestions
Discussion in 'Performance & Fuel' started by Cow_tipper 01, Jun 27, 2012.
  1. Cow_tipper 01
    Cow_tipper 01 New Member
    whats everyone running as far as plugs and wires are concerned? i need to do a tune up on mine and i figured i may as well upgrade(if its possible), while im replacing stuff anyways.
    Thanks!
  2. 99'HEARTBEAT
    The Vortec Engines, Run and Perform Better when using/going with, A/C Delco Plugs, and the one you would want would be the A/C Iridium Tip Spark Plugs, and for Wires, going with either Factory or Aftermarket, both will do the Job......for aftermarket wires, MSD....JBA....and Taylor are some to look at......For My Truck.....I've got the A/C Iridium Plugs installed and JBA 8MM Plug Wires.
  3. Cow_tipper 01
    ok awesome! thanks for the tips!
  4. Goldie
    Goldie Epic Member 5+ Years 1000 Posts
    X2 what 99 said. Don't try the E3 plugs! I used a set on my 07 4.3L and only got about 20-25,000 miles before they started misfiring and generally acting up. I replaced them with A/C OEM plugs and haven't had a problem for many, many miles.
