Plugged Cat???
Discussion in 'Chevy C/K Truck Forum' started by SGSelby, Jan 28, 2012.
  1. SGSelby
    SGSelby New Member
    So what would be the easiest way to test if my cat is plugged up?
  2. Untouchable
    Untouchable Member 2 Years 100 Posts
    What is happening that makes you think it's bad or clogged?
    The way I tested the one on my old truck is removing the O2 sensor to see if the idle and RPMs improved. The only other things I can think of doing is taking it off, or replacing it.
  3. Coach24
    Just unbolt the front connector and if your truck runs better with it disconnected , I would replace the Cat
  4. Strino78
    Strino78 Member
    A foul rotten egg smell in the exhaust is also an indicator that the cat is plugged/failing. Sulfur/sulfides give off a rotten egg smell.
