po332 code knock sensor moister problem help!!
Discussion in 'General Chevy & GM Tech Questions' started by burb4us, Aug 19, 2009.
  1. burb4us
    burb4us New Member
    my ses light came on 02 suburban z71 code reads po332 knock sensortruck is running fine I know these had a lot of problems with moister the ses light came on shortly after going through water puddle after heavy rain. how do I dry this out or do I have to replace the sensor or wiring?
    Thank you burb4us
  2. Jimmiee
    Welcome aboard. A scanner will tell you if your knock sensors are working or not. Make sure nothing is making noise under the hood like a valve lifter, exhaust leak or bad belt tensioner. A boom box will set a knock sensor code.:)
