Power Window Help
Discussion in 'General Chevy & GM Tech Questions' started by lumpy66, Jan 31, 2012.
  1. lumpy66
    lumpy66 New Member
    All of a sudden neither of my passenger windows work - I replaced the regulator and motor in both front doors within the last year. The front makes no noise and doesnt dim the lights when the switch is pushed but the rear dims the lights slightly and makes that slight clicking sound. Neither will operate from the main switch or the individual door switches.
    Please help with a diagnostic procedure I should follow - to check electrical with a multimeter, etc.
    I don't want to spend the money on the main driver's door switch assembly unless I'm sure that's the problem.
    Lumpy - 2003 Suburban
  2. murdog94
    Sadly this sounds like a BCM (body control module) which is very common on the GM trucks, and can really only be diagnosed by a dealer with the right software to troubleshoot it (some shops have the ability too)
