Power Window Issues
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by BigFalcone, Oct 9, 2009.
  1. BigFalcone
    BigFalcone New Member
    Ok i have a 01 z71 extended cab and my passanger window has gone weak. it won't roll up all at once you have to go about half way then wait a little while then roll it the rest of the way. I've replaced the motor already. Kinda need some ideas i don't wanna take it to a shop i always work on it myself.
  2. Dukeschevy
    Dukeschevy Rockstar 100 Posts
    I recommend old fashon crank down windows haha jk, I don't know much about them but I think the motor is controlled by something that controls the power. If it has issues it may not give the moter enough juice? or if it is not on track it might not roll up right, maybe someone else knows i'm just trying to help, good luck!
  3. Peckens
    Peckens Member
    power windows tend to do this alot, motor is probably goin
  4. BigFalcone
    i mean i replaced the motor and it didn't help at all i was thinking about the regulator and changing out the electrical relay. But was wondering if anyone else has had the problem maybe point me in the right direction.
  5. Eddie Z71
    Welcome to the site! I had a 1999 Chevy K1500 Z71, and the window did the same thing. I took the door panel off and sprayed silicone on the track. It look like the previous owner had taken it off to replace a speaker. I don't know if that was it , or I released a bind it was in when I took off the door panel , but it worked after that. Good Luck.
