Power window malfunction
Discussion in 'General Chevy & GM Tech Questions' started by Straightshooter, Aug 28, 2009.
  1. Straightshooter
    Straightshooter New Member
    My front passenger door's power window will not operate, but it is not electrical. I have had the door panel off and the window seems to get loose and gets in a bind. Are the rollers and/or guides replacable? I can't see any adjustment points that would stabilize the window. There appears to be a lot of "slop" in the window. Anyone had this problem?
  2. 2ToNe04
    What year of truck.?
    This is for 03-07 im not sure if the 99-02 are the same.
    Also if you have some White lithium greese laying around, i would greese up the rails where the window travels up and down on. Before you apply anything like whitelithium greese make sure the rail doesnt have any dirt or else its pointless, it will just grind all the time.
    Also there is 2 little clamps that have cushion on them clamping down on the window, you can try and tighten them, i believe its a 10mm socket. 1 bolt on each clamp.
  3. Straightshooter
    It's a 2004 Colorado crew cab. The two clamps that hold the glass are not loose but you can rock the window back and forth. None of the bolts for the motor are loose. With everything tight, you can grab the window and rock it back and forth in the tracks.
  4. Loggerhead Mike
    sounds like it slid out of one of the tracts, or your regulator may be loose. check all the bolts, there should be 4 more besides the bolt to the motor
