Powering Amp with stock battery Posts
Discussion in 'Audio, Video & Gadget Tech' started by Alaskan, Oct 19, 2010.
  1. Alaskan
    Alaskan Rockstar
    Hi,
    I'm currently trying to install an Amp and the problem I find is that my battery post has no room to add anything to it. How can I power my amp without buying a new battery? or disfiguring the one I have?
    Any help is much appreciated
  2. TritonBoulder47
    You have a fuse center under your hood... If you take the plastic top off and take off the plastic around it, there are 2 posts you can use, and they'll be fused right there in the fuse panel under the hood...
  3. Alaskan
    Alaskan Rockstar
    That was quick. I'll definitely look for the posts
    Thanks
  4. sstoner911
    Whats connected to the battery now? Seems odd you cant fit the ring over the battery post for amp wire.
  5. ntbush83
    here's what you need. I had the same problem till I bought this.
    [​IMG]
  6. TritonBoulder47
    Or you could just buy a dual post battery... My Optima Yellow-Top has the side and top posts... My factory battery cables go on the sides and all my accessories are on the top...
