problem with DIC check reset and customization buttons
Discussion in 'GM Electrical Tech' started by dbflyrod, Nov 14, 2013.
  1. dbflyrod
    dbflyrod New Member
    I'm trying to reset my average economy readout and holding the check/reset button does not do it. Additionally I'm not able to use the customization button to reset the system default or customize the feature settings. Any input would be greatly appreciated. I have read the book and I think I'm following the direction correctly.
    thanks
    DB
  2. GM Customer Service
    GM Customer Service Epic Member 5+ Years 500 Posts
    Hello bdflyrod,
    I am sorry to hear that you are experiencing an issue where you cannot reset the average economy readout. I would like to look into this concern for you. Please private message if I can be of any assistance.
    Jennifer T.
    GM Customer Care
  3. RayVoy
    I'm not a big fan of doing battery disconnects, but sometimes it is the solution.
    Maybe you DIC needs a re-boot/reset, try a battery pull.
  4. dbflyrod
    dbflyrod New Member
    Thanks RayVoy I did try that to no avale. I actually had a half hour finding out about the Pass key 3 + thing and did the battery deisconnect to see if I could fix that. Ended up doing the key on for 10 minutes thing to get through it. I think I either have a didconnect on the button cluster or bad buttons. I'm curiouse though as to why 2 buttons would be inop thus leading me to think more along the lines of wireing disconnect.
    DB
  5. dbflyrod
    dbflyrod New Member
    DIC is now working, thanks to all. I ordered a new switch from GM parts club, received it today and plugged it in, yeah!! it worked. After braking down the old switch to the circuit board I found some whitish like corrosion around the check/reset button area.
  6. RayVoy
    Sounds like water damage, clean it and it may be a good spare.
