Pulsating Lights
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by dfhollums, Jan 14, 2014.
  1. dfhollums
    dfhollums Rockstar 100 Posts
    1999 Chevy Suburban, alternator replaced earlier today, and the battery is around a year old. When the lights are on they pulsate, my wife told me that she saw the battery light come on and all the lights dimmed briefly then went back to pulsating when the battery light turned off. All the connections are good, so what could be the problem?
  2. tbplus10
    Have the battery load tested, also check the battery grounds.
    Then test that new alternator
  3. dfhollums
    Thanks for the tips, I will check that out. According to the build code for the alternator for the truck it is supposed to be a 105 amp and that was what I re-installed.
  4. 95C1500
    95C1500 Rockstar 100 Posts
    check all grounds like said above. Having a bad ground can do some weird stuff to a truck.
  5. poncho62
    poncho62 Active Member 2 Years 100 Posts
    Yup...sure sounds like a bad ground somewhere
  6. 08_rado_rocker
    08_rado_rocker Member 2 Years 500 Posts
    Definitely check all of your grounds. Ensure that when installing the new alternator, the plug going to the regulator didn't get damaged/unplugged. Make sure that the terminal wasn't damaged to the positive post on the alternator, as they can get corroded and become weak. I used to work at auto parts stores and have also seen SEVERAL "new" alternators bad straight out of the box. If everything related to the battery posts, terminals, and ground straps comes back okay, I would suggest that you return the alternator to the store you bought it and demand a replacement (even if it tested "good").
  7. DrumBound
    DrumBound Member
    As said previously, have the alternator tested and check your grounds. If you cannot seem to find a bad ground try to reground your alternator to the chassis. Seems to me that one of the windings in your alternator is bad, hence the pulsating effect.
  8. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    Alt! Don't ask how I know.
  9. dfhollums
    Much obliged for y'all's tips. O'Reilly Auto Parts warranted the alternator, the problem was most likely the internal regulator. I purchased a remanufactured alt. from the Ultima line because of the lifetime warranty, the Best Test version only has a 1 year warranty. Interestingly, I had advise from a counterman that was nearby the one helping me about going with the Best Test alt. over another Ultima version because of bad experiences he had with the Ultima alt., going through three on his vehicle in a months time, but having the "lesser" alt. in his vehicle for almost a year. He told me he'd give a week on me installing another alt. like the one I had before I'd be back again. I went with the Best Test alternator. Any others of y'all had similar problems with the Ultima line of hard parts from O'Reilly Auto Parts?
