putter putt putt
Discussion in 'GM Powertrain' started by johnmeade2, Mar 25, 2009.
  1. johnmeade2
    johnmeade2 New Member
    for some reason when i am driving through a parking lot or backing up or just driving slow, when i take my foot off the gas the truck starts to sputter like it wants to die (sometimes it does). what would cause that?
  2. k.daddy1
    k.daddy1 Rockstar 100 Posts
    What kind of truck, motor??
  3. Kady
    How long has it been doing it for?
    Bad gas maybe? Spark plugs/wires? tune up? could be tons of stuff.
  4. johnmeade2
    its a 95 silverado with a 350 i have only had the truck a month and it started doing it about a week after i bought it. I changed the plugs, wires, dist. cap, oil, air filter, had the throttle body cleaned, I even took it to auto zone to see if they could get some codes from it and they got nothing, it's not too much of a problem but it very annoying!
  5. Springthing
    I'd say throw a can of SeaFoam into it next time you fuel up and maybe pick up a second to do the intake and all. It will clean things out a little bit more and hopefully take help with the issue.
    Like Kady said.. it could be one of quite a few things. From air/fuel mixture, idle, failing o2 sensor perhaps? Good luck with it all.
  6. werty
    werty Rockstar 100 Posts
    I had a truck like that once......man i miss the cam in that thing...you could almost count each cylinder firing....:great:...Does sound like fuel though/.....
  7. ChevyFan
    :sign0018:Just a reminder that everyone should update their profile and signature to give people answering your questions a head start and this will provide faster response time. See my signature for more info on that.
  8. bry2500
    Ditto on the seafoam.
    I would check the EGR too and test for vacuum leaks. good starting points since you've already tuned it up.
  9. k.daddy1
    Unfortunately you have a truck with the engine that has a history of intake issues. What you are describing is a typical intake problem. Pull the plugs on the passenger side of the engine. If you notice a crusty build up on the electrode, the intake is leaking anti-freeze and sucking it into the engine fouling the plugs. That will cause the idle issues, but if the plugs are clean and grayish in color, remove the EGR valve and clean the carbon out of it, re-install and run the sea foam. I'm 99% sure you'll find your problem with the intake gasket leaking.
    1 person likes this.
