question about fuse block
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by scgamer_99, Apr 11, 2009.
  1. scgamer_99
    scgamer_99 Rockstar
    i have been looking everything over in my truck because i am planning a trip so while i was checking fuse's and such i had out the chilton just making sure the correct fuse is where they are supposed to be when i got to wondering what are the aux a and aux b hooked up to? the chilton doesn't even mention them any ideas? beacuse they are supposed to have 30 fuse's in them but aux b has a 20
  2. KidHauler
    Aux A and Aux B are auxilary battery power hook-ups. On mine, Aux A feeds my e-lights, Aux B feeds the trailer brake.
    Look at your diagram - the posts above the fuses you circled are the corresponding outputs. (toward the firewall when you look in the truck) These give you a good solid connection for bigger power draw equipment.
    Hopes this helps,
  3. scgamer_99
    scgamer_99 Rockstar
    ah i see so this would probably be the towing power line then? i do have a tow hitch under the truck never used it though, good to know just in case i do tow though thanxs for the help
  4. meash20
    meash20 Rockstar
    what year, and model... you may want to add that to your signature for future reference...
  5. scgamer_99
    scgamer_99 Rockstar
    ah soory bout that
    95 k2500 sle gmc
  6. Springthing
    I just added some lights to my Suburban and used both of those Aux spots. Seems to be working fine - go nuts!
