Question on Seats??
Discussion in 'General Chevy & GM Tech Questions' started by richregan, Feb 10, 2013.
  1. richregan
    richregan New Member
    I have a 1995 1500 short bed that has a bench seat. I would like to swap it out for some kind of seat that I can recline the back. My knowledge is pretty limited, so I need some help to know what will fit, and how difficult it will be to swap out seats.
    Thanks
    Rich
  2. RayVoy
    Assuming you have a crew, or extended cab, you should be able to use GM buckets and console from the same style truck.
    The bucket seats use the same mounting holes as the bench.
    A buddy of mine swapped out the front and rear seats in an extended truck, he said it only took a couple of hours.
  3. tbplus10
    As Ray pointed out the cab configuration is going to be the limiting factor on this swap, the seats fit right in but if its a std cab truck theres no room to really recline them.
  4. richregan
    Thanks for the replies...The truck is a standard cab, so even though there may not be room to recline the seat, I can still get it in there, right?
  5. tbplus10
    Yes they fit, in certain trim configurations theyre an optional seat from the factory for your truck.
