Raptor Spray In Liner
Discussion in 'How-to Guides' started by lonelywolf858, Jun 26, 2013.
  1. lonelywolf858
    lonelywolf858 Rockstar 100 Posts
    I've had 5 trucks now and have done a roll-on bedliner in every one of them. I've tried a different brand with every truck and I think I'm most pleased with the looks of this one. I'm curious to see long term durability.
    Raptor Kit:
    4-bottles of liner
    1-can of hardener
    1-spray gun
    Other Materials:
    100 grit sandpaper
    Scotch bright wheel
    Scotch bright
    Self etching primer
    Painters tape
    drop cloths
    Step 1:
    I washed the bed thoroughly with a wax and grease remover to get rid of years of car wash build up and oily residues.
    Step 2:
    Sand the finish until all the gloss is gone. I used a sander with 100-grit for most of it. Then I came back with the Scotch bright wheel followed by hand scrubbing with Scotch bright. This got rid of almost everything except the tight corners.
    Step 3:
    Since no one is perfect you may sand too deep and get to bare metal and you may not be able to get into the tiny crevices. Use a little self etching primer in these areas.
    Step 4:
    I disassembled everything I could to make masking easier. Make sure you double and triple check your masking because nothing will ruin your mood like blow-by.
    Step 5:
    Mix and spray a first coat like the Raptor instructions.
    Step 6:
    I followed the instructions and put on a 2nd coat on the entire bed and a 3rd coat on the floor, tailgate, and wheel humps. You may be able to do more or less depending on your bed.
    Step 7:
