Rear Differential
Discussion in 'GM Powertrain' started by Jarrett, Jan 11, 2010.
  1. Jarrett
    Jarrett Rockstar 100 Posts
    Does anyone know about how hard it would be to change the rear differential in my 98 K-1500? Does anyone have any ideas about what I could use to replace my rear differential, which does not have posi-traction? What about a locker rear end, or a limited slip?
  2. MrShorty
    If you are considering rebuilding your existing differential, you can put almost anything in there: a limited slip or a locker -- it all depends on your budget and what you want to end up with. If you have an open carrier and don't have to completely rebuild, there are a few "lunch-box" lockers that replace the spider gears that can be installed.
    As far as how hard it is? From what I understand, the most difficult part of rebuilding a differential is setting up the gears. It isn't "difficult" per se, but the tolerances are very tight, and a mistake ruins your ring & pinion gears, and means you have to do it again. Usually this isn't recommended for the novice. If you have to ask how difficult it is, I'm thinking you want to think long and hard about setting up your gears yourself.
    A lunchbox locker doesn't require any kind of gear set up, since it uses the existing carrier. If your existing differential is in good condition, and you just want to get the added traction, this may be an option worth considering.
