rear door wont open
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by jpierce125, Jan 28, 2010.
  1. jpierce125
    jpierce125 New Member
    i got a 96 suburban and the rear hatch wont open i can hear it unlock but no go is htis an expensive fix?any info would help thanx
  2. unplugged
    Shouldn't be a big deal. Hop inside and crawl into the rear. You'll need a screwdriver and a panel tool. Take the passenger side panel off and you will be able to see what's not working. It is helpfull to have someone on the outside to operate the latch just to give you a visual on whats going on. There are rods and levers that open the latches. One of the rods is bent or could be a lever is disconnected. Take some pics while you are in there and post the info for others in need of the same help.
  3. Rivieraracing
    Rivieraracing Member
    More than likely a rod from your outside door handle has come undone, do like mentioned and your problem should be easily fixed!
